Hi all
Can anyone possibly explain what the differences between the following are:
Voltage stabilizers
Voltage regulation
Power factor correction units?
We run a large fabrication shop with five large welders and other power consuming devices.
From what I understand above, the power factor correction units, using capacitors even out the sin wave between reactive and active current flow.
Voltage regulators give one a even (constant current) similar to stabilizers.
But, in a factory (or shop, or even common household) one will be better or more suited than the other.
Anyone able to explain in layman's terms what the difference is?
Voltage stabilizers
Voltage regulation
You should discuss this type of investment/installation with an independent consultant before taking any decisions. I wouldn't let yourself get railroaded into a PFC installation of this nature by the supply authority of the agents of the equipment.
