Easyfile Employer 6.0.4 Login Problem
  • Claudette
    • May 2012
    • 6
    After I've installed the the new version of easyfile (v6.0.4), I've been struggling to login.
    When I click on login, there's a little clock running and eventually it tells me client has been timed out.
    I'm running on Windows 7. Someone please help with a solution.
    • 22820
    What OS are you using, Windows 7, Windows XP?
    • Claudette
      • May 2012
      • 6
      Hi Dave, I'm running on Window 7. Already tried uninstalling and re-installing. Even when I click on the close button from the login page,
      it stays stuck on "CLOSING DATABASE". Eventually I must force close it with Ctrl+Alt+Del. PLEASE tell me you have a solution?
      The call centre yesterday was of no help, just told me she'll "escalate" my problem...
        • 22820
        My thought was - Try running the program as an administrator (Right click on the icon - Run as administrator).
        Could you let us know if that solves it, please.
        • Mike C
          • 2895
          If you have AVG Anti-virus it can also cause a hassle with Easyfile. I still have the SARS instructions on this and can post it if you suspect that it might be causing the hassle.
          • Claudette
            • May 2012
            • 6
            Running as administrator did not solve the problem
            The anti-virus I'm using is Kaspersky.
              • 22820
              The next thing to try is to see if there is any difference working offline vs online. Or try installing on another machine.
              • Claudette
                • May 2012
                • 6
                Even though the program is "stuck" on the login screen, it picks up when I turn my Wi-Fi off, telling me I can work in offline state but
                have to be online to be able to submit. When I click ok to this message, I'm still on the login screen.
                In May I had a similar program, was able to login but couldn't access any of the data bases. I found a solution on this site where I had to
                go and delete a dbz.jnl file somewhere in the AppData\Roaming\Local Store folder.
                Yesterday the lady at call centre told me I must delete easyfile from the db folder, not sure where this is, but I've originally deleted going the
                Control Panel/Programs and Features route.
                Installing on another machine is not really an option for me, only have my laptop.
                • Mike C
                  • 2895
                  Hi Claudette - Did you ever solve this problem? This morning I decided to log into EasyFile 6.0.4 to see that all was ok in preparation for the mid year reconciliation and had the same problem. Tried logging in as Administrator - updated Adobe AIR - nothing. Just hangs when you try to log in.
                  Anyone else experience this?
                  • Janine N
                    • Aug 2012
                    I have tried logging on as Administrator, have updated Adobe AIR and I get the error message :
                    "e@syFile has detected that your login information does not match that of the local information and as such you will not be allowed to access e@syFile".
                    • geraldenek
                      • Jul 2008
                      • 229
                      Is IE your current default browser? if not, change it to IE and reopen easyfile.
                      Geraldene Kapp
                      Professional Tax Help
                      www.mytaxhelp.co.za
                      • Mike C
                        • 2895
                        Hi Geradenek - thanks for your reply. I usually use firefox - but tried your suggestion. No luck.
                        I also tried restoring my last backup and it gives me an error #1009.
                        Any other suggestions?
                        • Mike C
                          • 2895
                          OK - I've got it sorted.
                          I had the latest JAVA 7 Update 5 - but it seems as though Easyfile likes Java 6 update 6. I discovered this by removing and reinstalling Easyfile.
                          In spite of Java suggesting that you remove older installations of it, you would be wise to leave version 6 update 6 alone.
                          Hope this helps someone else.
                            • 22820
                            I'm on Java 6 update 17 and no log in problems to report.
                            I've had something bizarre happen to my 2012 EMP 501 recon submissions.
                            When I print the employee certificates the data in the certificate doesn't match what I captured.
                            But no log in problems
                            • Claudette
                              • May 2012
                              • 6
                              Thx Mike. I've uninstalled the latest java, keeping v 6 upd 6 like you've suggested, re-installed easyfile again, and it works!
                              Will be sleeping a whole lot better 2nite.
