Results 1 to 5 of 5
Thread: Easyfile merge problems
    Oct 2012
    Prieska
    Hi good day,
    Can somebody tell me if you do a backup of E@syfile, if it is suppose to back the file as a zip file?
    Because mine does, I am not able to use the merge function, as the merge function doesn't seem
    to read the zip file.
    Please advise.
    thanks,
    Miello
    Diamond Member Mike C's Avatar
    Apr 2012
    Umkomaas
    Hi miello9 - yes it now zips the data. Started doing this from about version 6 I think.
    I have never done a merge, but it should be possible from within Easyfile.
    Merge multiple databases
    This process should be used where:
    • Multiple branches or different employees complete manual certificates and payroll files, and these should be merged for the
    reconciliation.
    • Data for different financial periods should be merged onto one single database.
    With the introduction of split database files for each PAYE number within the e@syFile™ Employer directory, the merge process has been amended to combine one employer database file at a time. When merging another user’s data with your existing e@syFile™ Employer database, one employer database will be selected, to merge with your data.
    This will enable tax practitioners, payroll consultants and users with multiple PAYE reference numbers to create e@syFile™ Employer database or back-up files for a single PAYE reference number.
    Note 1: To ensure that no certificates are lost during the merge process, different certificate numbers or ranges should be
    assigned to the different staff members preparing manual certificates. Back-up all data to be merged, and transfer these
    files to a selected folder on the PC where the various databases will be merged.
    Note 2: A new backup file (version 6 and later) will need to be ‘unzipped’ before the data can be merged with the existing
    e@syFile™ Employer data. Access the folder where the back-up has been saved that you wish to restore. Extract or ‘unzip’
    the file before proceeding with the merge process.
    Dave A (24-Oct-12)
  4. #3
    Looks like that's the key.
  5. #4
    Full Member tax$$$'s Avatar
    Jun 2011
    Northen Cape
    Hi miello
    Its like they say, unzip and merge them one for one. Be careful though. I merged a file and EasyFile 'not responded' and had to force exit. For some reason all files under AppData was deleted. Just make sure you backup every time.
  6. #5
    Apr 2012
    Umkomaas
    Very good advice Tax$$$
  1. Easyfile 6.1.2. loggin in problems
    By Yollie in forum Tax Forum
    Last Post: 02-May-14, 08:30 AM
  2. Replies: 1
    Last Post: 09-Oct-12, 07:21 PM
  3. Easyfile ver 6.0.2 not working
    By Lisa2404 in forum Tax Forum
    Last Post: 04-Jul-12, 04:44 PM
  4. e@syfile 6.0.0 database merge problem
    By Maynu in forum Tax Forum
    Last Post: 24-Apr-12, 07:50 AM
  5. Companies merge
    Last Post: 17-Sep-11, 02:45 PM
Tags for this Thread
