Results 1 to 3 of 3
Thread: Pastel Partner - incorrect page size or paper style - help
    Feb 2017
    Please can you help me? I used to be able to print fine and then now all of a sudden when I try to print an invoice or statement is says incorrect page size or paper style. I have gone into file - printer/font setup and the option ticked is "get paper directly from printer" and plain, single sheet. I have also gone into Setup - auto setup and it is also on the "plain single sheet". Maybe somewhere I have st select A4 size paper but I don't have a clue where to.
    I hope that you will be able to help me
    Thanking you in advance
    Justine
    Westville, Durban
    Hi Justine,
    You are on the right track.
    Pastel uses A4 paper size, but it is likely that your printer driver is set to Letter paper size.
    Open your printer driver in the Windows Control Panel, and right-click Printer Properties, and look for all references to the paper size and change to A4 where necessary. Depending on your particular printer driver, you might have to check under 3 tabs, i.e. General, Advanced and Device Settings.
    Then go into Pastel and re-select the printer under File...Printer/Fonts Setup, in order to refresh the settings in Pastel.
    Feb 2017
    Thank you so much, very appreciated. It is working perfectly now. Thanks again!
  1. Help!: Incorrect page size or paper style error on print!
    By TravisZA in forum Accounting Forum
    Last Post: 01-Nov-19, 02:45 PM
  2. [Question] Change Quantity Field Size in Pastel
    By JPdp1989 in forum Accounting Forum
    Last Post: 17-Sep-15, 01:44 PM
  3. [Question] Pastel Partner: Printing customer/ supplier invoice on paper or pdf
    By VKus in forum Accounting Forum
    Last Post: 05-Mar-13, 05:48 PM
  4. Lite skin for dial-ups or to reduce page download size.
    By Dave A in forum Administrative issues
    Last Post: 08-Jul-08, 10:12 PM
