Originally Posted by
Derlyn
Morning
During the last spate of load shedding, I was called out on a number of occasions for prepaid meters not switching on again after load shedding.
When this happens, the display is normal, showing the units available, but the internal contactor has not energised. Don't know why this happens.
Here is the solution without having to contact the supply authority.
On Conlog meters, type in the following code: 5649 3153 7254 5031 3471
For ALL other meter types, type in the following code: 0000 0000 0001 5099 7584
The above codes trip and reset the meter a couple of seconds later and the contactor will then energize.
The above scenario seems to occur more with Conlog meters as all these callouts have been to Conlog meters.
Important:
Should the meter be of the type with a battery powered remote unit, the meter can still be tripped using the above codes, but it will not
switch on automatically after a few seconds. The code needs to be punched in a second time to switch the meter on again.
Make sure the batteries in the remote unit are good otherwise it ain't gonna work.
Hope this helps.
