Originally Posted by
Justloadit
Seems every one has been lucky so far.
I have had a situation, in which over night a gel 35A battery failed in a small inverter which has a constant voltage and current limited battery charger, not sure what happened to the battery as the charger did not fail, but the gel in the battery boiled, the plastic bulged and cracked, and released some horrible smell into the air and liquid came out the battery.
Luckily when I came in I smelled this and was able to identify the issue. Not sure what would have happened if it was not detected in time.
I suspect that one of the cells failed as a short circuit. In most cases with lead acid, the cell fails where the cell capacity changes, which causes the terminal voltage to raise quickly shutting off the charger.
