Results 1 to 3 of 3
Thread: 3 phase minimum voltage
    Mar 2022
    Gauteng
    Morning all
    I know the minimum permissible single phase voltage is 207v. What is it for 3 phase? Is the minimum voltage calculated on 380v,400v,415v? My phone crashed so I lost my 10142 I had on it.
    Sent from my SM-A336E using Tapatalk
    Jun 2020
    Fourways
    The equipment shall be suitable for operation on the maximum steady (r.m.s.)
    voltage and overvoltage to which it is likely to be subjected. Equipment shall
    be rated in accordance with the intended application for use on one of the
    following voltages used in South Africa:
    a) A.C. circuits:
    1) standard voltages of
    i) 230 V single-phase,
    ii) 230/400 V three-phase four-wire, and
    a tolerance of ± 10 % on these voltages.
    NOTE For certain equipment it may be necessary to consider the lowest voltage
    that is likely to occur.
    2) declared voltages of 525 V three-phase three-wire is a commonly used
    voltage and the tolerance is ± 5 %.
    NOTE Declared voltage is the voltage declared by the manufacturer up to the
    maximum of 1 000 V.
    SAB
    madscot (30-Aug-23)
  4. #3
    Mar 2022
    As Dylboy mentioned 10 %, however you have to take the voltage on site into consideration.
    The sit eI am working on at the moment
    Red = 221
    White = 225
    Blue = 228
    While carrying out tests today the voltage fluctuated more than 10 volts from one DB to the next.
    I have a site where I connected a PQA, the grid voltage ranges from 260 VAC down to 165 VAC, reported to the supplier, they sent a sparkie with a duspol tester to fix the issue. We have had to install online UPS units to stablise the power to prevent damage to the servers.
  1. Changing 3 phase electric DB to single phase. (Switchover etc)
    By Janbez54 in forum Electrical Contracting Industry Forum
    Last Post: 05-Jul-21, 07:59 AM
  2. Inverter diagram for one phase on 3 phase installation feeding 2 db’s
    Last Post: 19-Aug-20, 06:44 AM
  3. Single phase generator feeding 1 phase of 3 phase db - discuss.
    Last Post: 03-Jul-18, 10:06 AM
  4. 3 Phase Voltage Problem
    By BlueArc in forum Electrical Contracting Industry Forum
    Last Post: 25-Jan-13, 02:48 PM
  5. Difference between: Power factor correction, Voltage regulation and Voltage stabisizi
    By BigRed in forum Electrical Contracting Industry Forum
    Last Post: 08-Feb-10, 09:29 PM
