With the RSS is it only possibly to get the first post of a thread?
rss feeds
If you don't mark the feed as read, you'll only get the first post.
I'm not sure what happens once you mark the feed as read (but I'm about to experiment).
I seem to recall that if you follow the link in the rss feed and post a reply you'll get updates when there is a new post. But again, I'll have to experiment.Participation is voluntary.
You can set it under feed properties in your rss veiwer. It can range from once an hour to once a week!
I'm going to go scrounging for switch properties that might resolve the first post vs full thread issue.
The alternative is to subscribe to a thread, or forum, or the whole board - this would give you email updates. But that's a little messier than an rss solution, I think.Participation is voluntary.
Let's put it this way. At about 12.15pm this thread was in my rss viewer - and the thread was posted at about 11.00am. (I've set the feed at once an hour). I also think this is a pull technology, so the update schedule isn't driven by the feed generator on the site, but by your feed reader.
BTW - I've got to say that IE7 makes handling rss feeds dead easy.Participation is voluntary.
I've just loaded this as a secondary rss feed to check behaviour. It sorts and produces based on last post as opposed to first post.
PHP Code:http://www.theforumsa.co.za/forums/external.php?type=RSS2&lastpost=1
