Forum Applications for Mobile Phones
ThanksWould be awesome if I could easily get my dose of TFSA on my Blackberry when I'm not at the PC!
LinkedIn
Bafokke Shirts - South Africa's No. 1 Fan Shirt!Comment
Do I sense some addiction here ?Martin Coetzee
www.straptite.com
You may never know what results will come from your actions, but if you do nothing, there will be no results... Rudy Malan † 05/03/2011Comment
LinkedIn
Upon closer inspection, there is no obvious reason as to why Blerryblab isn't working. All the required files are present and accounted for.
Maybe I should point out this is not an auto-detect type of app. I think you have to add The Forum SA as one of your chosen sites using the Blerryblab app (somehow).Participation is voluntary.
Maybe I should point out this is not an auto-detect type of app. I think you have to add The Forum SA as one of your chosen sites using the Blerryblab app (somehow)."The way to gain a good reputation, is to endeavor to be what you desire to appear." - Socrates
LinkedIn
With the transfer there have been some critical changes, but a quick skim through the code looks like this should all have been auto-detected. I can only suggest you try to add the forum when you're on this page http://www.theforumsa.co.za/forums/ as it's the home folder location of the Berryblab files.
If that doesn't work, this is going to take a bit of digging and I'll have to ask for a little patience.
I'm hoping to take a week off work next week with the main goal of running over the entire installation of TFSA, cleaning up issues and adding a few things on my to-do list for the site.
Between the load issues on the previous server and load issues at work, maintenance on TFSA has been... less than optimal. I've been forced to focus on what I could drop as features rather than what I wanted to add, and have been dealing with broken stuff only when it's been fairly critical.
Happily, the server limitation issue seems to be a thing of the past (at least for the time being). So now it's just a case of allocating some dedicated time.Participation is voluntary.
At first I thought I had some settings wrong with my phone's APN, but then when I managed to add another forum I figured it couldn't be. Thank goodness it was just something simple like that.
Thanks for the help Dave."The way to gain a good reputation, is to endeavor to be what you desire to appear." - Socrates
LinkedIn
I'm chuffed that solved the problem. It struck me that if you tried just anywhere on the site (such as the site home page) there was nothing in the code to guide it to the key files it needs to work.Participation is voluntary.
Dave, can you think of anything you did today that can cause me having problems viewing the forum properly from my notebook using a Huawei E220 modem? I can't see any images since this morning. It looks really crappy without images and it seems all style sheets are gone.Roelof Vermeulen (Entrepreneurship in large organizations)
Enterprise Art Management Software| Rock flaps south africaComment
Try CTRL F5 for a full refresh of the CSS. The only settings I changed yesterday was to extend the TTL in the nameserver's SOA.Participation is voluntary.
Grrrrrr, I knew that!
Did the trick, thanks Dave!Roelof Vermeulen (Entrepreneurship in large organizations)
The Tapatalk app download info page is here.
If you do go the Tapatalk route, please let me know. I deactivated the API here a while ago because no-one was using it. But if it is going to get used, I'll get the latest version and get it back up and running.Participation is voluntary.
