How do I disable the Outlook warning message when emailing out of Pastel?
  • JLC
    • Aug 2012
    • 20
    [Question] How do I disable the Outlook warning message when emailing out of Pastel?
    Every time I try to email an invoice or statement out of Pastel (Partner 7 Version 11), my Outlook 2010 (operating system Windows 7, 64 bit) won't send the message automatically but comes up with a warning message "a program is trying to access email address information stored in Outlook. If this is unexpected, click Deny and verify your anti-virus software id up-to-date ...." ; after clicking "allow" twice the email is finally sent. 400 invoices later, my fingers and patience are both stretched to the limit!
    Please someone help!!
  • Neville Bailey
    • 2786
    Download ClickYes from here - it will run in the background and auto-run the "click yes" routine in a blink!
    Once you have installed ClickYes, you will see it in your system tray. Right-click on the icon and make sure that only the "Start on Logon" option is ticked.
    • JLC
      • Aug 2012
      • 20
      Hi Neville - thank you so much! I have been battling with this for ages - you are a star!
      • Raene
        • Nov 2012
        • 43
        This is brilliant - thank you Neville, also been struggling with this for ages. It is strange that Pastel would not have a work around for this issue.
        • Neville Bailey
          • 2786
          Actually, it is not a Pastel issue, but rather an Outlook security issue. Outlook is simply asking you to confirm that it is allowed to send an email that has been generated from an outside application, i.e. Pastel.
          • Mike C
            • 2895
            Does anyone know of a similar program that would work with other email packages?
            • JF Group NZ
              • Mar 2014
              • 5
              But Pastel is not yet a "Trusted Partner" of Microsoft so the problem is unable to be solved. If they did have this then it's simply a matter of ticking a box to allow the program access??
              • DavidR
                • Apr 2014
                The free version only works with Outlook versions 2000, 2002 and 2003 according to their website:
                Express ClickYes is a tiny program that sits in the System Tray and clicks the Yes button on behalf of you, when Outlook's Security Guard opens prompt dialog saying that a program is trying to send an email with Outlook or access its address book.
                • DavidR
                  • Apr 2014
                  Won't be much help with Pastel as Pastel only works with Outlook. Why does Pastel not write its own Email routine that does not require Outlook. It should be able to send straight to an SMTP relay server without need Outlook.
