Help please. I have just migrated from a pc to a mac. I am running windows & on my mac utilising paralles 7 which allows you to run all windows software on your nmac as if you were running them on a windows based pc. All my other other windows software works on my mas. Except Pastel Partner 2011.I am getting run time error "53" file not found: WBttrv32.dll which I know has to do with the pervasive data base. I have uninstalled the pervasive databases, turned off antvirus and firewall programs, rebooted the machine and reinstalled pervasive but it did not solve the problem. I still bot error "53" Any help would be greatly appreciated.
Error 53 Help Please
Adrianh is my hero...
BOVER Technologies - computer sales and TeamViewer support
Elmine Botha Freelance Photographer - Photographer/ VideographerComment
Hello Lionel M,
This dll is a pervasive dll, i suggest removing pervasive if you have already attempted to install it and re-install, if you are using version 8 or 9 of pervasive then use the pervasive system analyzer which is located start --> all programs --> and at the top you should see pervasive system analyzer, if not then i suggest you uninstall it via add and remove programs.
Hope you found this helpful.Comment
Thanks AAron - it was extremely helpful. It solved my problem. My apple was not rotten after all.Hello Lionel M,
I wonder if Adrianh's Blackberry is frozen!!!!Comment
Keep up the good work adrianh...
Hehe...
