Run-time error '5': Invalid procedure call or argument
I have pasted an extract from my Pastel Knowledge Base, which might assist you:
There could be 2 causes for the problem; there is no mapped drive to the server or the registration on this workstation is corrupt.
Steps to create a mapped drive:
- Double click on My Computer
- At the top of the page, click on Tools - Map Network Drive.
- Select a new letter from the list. It is best to map a network drive on the same letter as the other machines on the network. For example, if all the computers on your network have Pastel mapped on the P:\ drive, select that letter for your mapping.
- You will then click on browse and look for the Pastel folder on your server through My Network Places - Entire Network - Windows Network workgroup name (the icon is three computers joined together in 'network') - Server Name
-Once you find the Xpress11 folder, click on it and click on Ok, then click on Finish.
Registration on the server is corrupt:
-Go to C:\Xpress11\Custom and rename the Registration folder to old.
-Run a repair on Pastel thereafter and re-registerNeville Bailey - Sage Pastel Accounting Consultant
WALLACE WATTLES (1860-1911) -
You can also try this: If you have an older backup before you started receiving runtime error 5, you can locate the accuser.dat file in that backup and extract it to replace the one in your current company folder. You would then just have to make sure your document numbers are updated to the last document number used i.e. invoices , quotes, sales orders etc, also if any new users where created since then you would need to recreate them too. Please make sure you have a backup of your current company before attempting this.
Hope it helps.Farren Maré - Pastel Specialist
www.thebeancounter.co.zaComment
Hi all,
The client got the error again and went to Pastel for them to have a look. Apparently is was the User Control settings in windows that was not set correctly and caused the error. Apparently the client would have continued getting this error if this wasn't adjusted. The Pastel consultant adjusted these settings to the correct level, but the client could not tell me where the settings and which settings were adjusted (so that I could know for future reference). But I just thought I would post this here in case anyone has this error in future - it will be a good starting point to resolve this error.Comment
