Pastel Project Code: How to change a project code allocated to a client invoice - The Forum SA
  • JenineB
    • May 2012
    • 21
    [Question] Pastel Project Code: How to change a project code allocated to a client invoice
    Hi,
    Is there an easy / prefered way to change a project code against an client invoice without the change showing on the customer account (in other words without issueing a creditnote and then an invoice against the correct project.
    Regards,
    Jenine
  • TravisZA
    • Sep 2014
    • 108
    Bump.....does anyone know a solution to this????
    • Neville Bailey
      • 2786
      No, you will need to process a credit note and re-invoice the customer to correct the project code.
      Having said that, I am sure I can "fix" misallocated project codes with my database editor, as a one-off exercise...
      • TravisZA
        • Sep 2014
        • 108
        Thanks Neville, but I'll just process a credit note. There are only a couple I processed incorrectly so its not alot of work - just a little messy.
