PASTEL V11 - OPENING A COMPANY
  • Joanne021
    • Jan 2014
    [Question] PASTEL V11 - OPENING A COMPANY
    Hi ,
    I have a problem with my pastel.
    I have taken a file from another computers pastel drive and pasted it onto my computers pastel drive.
    I cant add it to my pastel. Why ?
    I have opened the folder and realised that there are 2 backups in it. Theres 1 backup in the folder of that Company and when you open that one, theres another in there. Please help me.
    Thank You
  • Mike C
    • 2895
    Hi Joanne - is the other computer running the same version of Pastel?
    • Jayshreeb
      • Nov 2017
      • 4
      I have a similar problem..it tells me that I have exceeded the number of companies...please help
      • UniquelyJanine
        • Mar 2017
        • 40
        Joanne021 :I suspect the extracted backup is incomplete. It looks if specific file exists to validate that its a valid company. You might want to try extracting the second backup perhaps.
        Jayshreeb : You will need to upgrade in order to add more companies once you have exceeded the maximum amount of companies.
        • Jayshreeb
          • Nov 2017
          • 4
          it allows me to access it from the external hard drive but will not allow me to add the company if i copy it to the c drive.
          • Neville Bailey
            • 2786
            When you initially added the company to the external hard drive, your single-company limit was used at that stage.
            If you then add another company to the package, it will regard it as a second company, even if it's a copy of the original company, because they are not in the same location.
            You will need to contact Pastel for a Reset utility, in order to reset the system to what it was before you added the company on the external hard drive.
