Trial Balance Profit not agreeing to Balance Sheet
  • razorc
    • Mar 2014
    [Question] Trial Balance Profit not agreeing to Balance Sheet
    Hi Guys
    I am trying to help my mother with a problem she is having with her pastel books.
    Her profit per the trial balance is showing a certain amount and then on the Balance Sheet the "Net Profit/Loss this year" is different.
    It is very strange....So the Nett Profit per the TB does not agree to the Profit on the Balance Sheet.
    Surely, these 2 should match. I have no idea why there is a difference.
    Do you guys have anyway that I could troubleshoot this problem??
    I cannot understand why the 2 profits for the same period are different.
  • Mike C
    • 2895
    Hi razorc - the first thing I would do would be to run a data integrity test to check that there is no problem there.
    If that is ok - then just double check that you are looking at the same year. To look at the previous year, you untick a box ... and it is very easy to not notice it when running two different reports. A small thing like that can easily cause confusion.
    • razorc
      • Mar 2014
      Thanks Mike. It is definitely the same periods we are looking at. And we have even looked at it every month for the current period and there is a variable difference every month.
      It is so strange that our trial balance balances but the balance sheet does not.
      I will give the data integrity test a bash and see what happens.
      • CLIVE-TRIANGLE
        • Mar 2012
        • 886
        Presumably the Trial Balance balances?
        Presumably the Balance Sheet balances?
        If the profit does not agree, but the two statements are in balance, then there must be a compensating error. So just agree the rest of the balances in the balance balance sheet with the trial balance.
        Edit:
        If as you say, the Balance Sheet does not balance, then hopefully your data integrity check will fix it.
