Pastel Partner 12 cashbook updates from csv
  • cecile777
    • Dec 2013
    Keep getting Run Time Error 9 when trying to update cash book payments, using Pastel partner 12. Any suggestions please
  • Mike C
    • 2894
    Hi Cecile - this could be a problem with the Cashbook batch.
    To resolve the error, you need to export, delete and then import the cashbook batch.
    First make a backup - so that you can restore if anything goes wrong.
    Step 1: Exporting the batch
    On the cashbook screen, click on the Batch button.
    Select Export.
    Click on the magnify glass next to the white block under Export File Name.
    Select a location where to export the file to and next to File Name type in receipts.csv (if exporting the receipts batch) and payments.csv (if exporting the payments batch.)
    Step 2: Deleting the batch:
    On the cashbook screen, click on the batch button.
    Select Delete Batch.
    Click Yes on the Delete this Batch screen.
    Click Yes on the "Are you sure?" prompt:
    Step 3: Importing the batch
    Select Import.
    Click on the magnifying glass next to the white block under Import File Name.
    Select the file you exported earlier, click Open, Process.
    If there was open item matching on the batch then Press F3 on each line and match again as everything would have been unmatched
    Now try to update the cash book again.
    If the above did not resolve the problem, then you might need to delete the batch (as explained under Delete) and re enter the batch.
    • cecile777
      • Dec 2013
      No Luck!
      Hi, I have tried the above but had no luck. I import very large payment csv batches, which I convert to comma delimited with an Excel macro. has always worked very smoothly. The file is enourmous and I would hate to re-convert, and allocate eash transaction again.
      Is there anything I can look for in the batch that could be causing the problem?
      • Mike C
        • 2894
        Hi Cecile - the only thing that I could suggest then, is that you only import the first half of it and try updating. If the first half crashes, then - restore your database - import the first quarter, and try again.
        By trial and error you may find which section is causing the error and then whittle it down until you find the offending entry.
        I know that it sounds like a major hassle - but it should be considerably easier than allocating each transaction again.
        Just make sure that your original file is backed up so that you can restore each time.
        Neville Bailey is the expert on things Pastel around here. Perhaps you could ask him to have a look at your batch file and offer a suggestion.
