Easyfile Payroll File Import Fail
  • jtheron
    • May 2014
    [Question] Easyfile Payroll File Import Fail
    I have received an error report on easyfile saying the payroll file import has failed. The error report found under the import payroll file log shows the following message: Income Received code 3703 may not be reflected on an IRP5/IT3(a) certificate
    This code is used for a non-taxable reimbursive travel allowance. Is this code no longer a valid code? I created manual IRP5's on easyfile and used this code and there was no problem however with the import of the payroll file it is giving me the above error report.
  • Mike C
    • 2895
    As far as I know it is still valid.
