Pastel Xpress - free format invoice details - The Forum SA
  • saxophone
    • Sep 2014
    • 10
    Can anyone please advise how i can type free format comments for my invoice line in Pastel Xpress
    I need to set out lots of detail for each invoice of the services performed.
    Every invoice will be different so i can set this up as a service item
  • Neville Bailey
    • 2786
    Select the Remarks line option (option 7) for free-form comments.
    • saxophone
      • Sep 2014
      • 10
      Thank you for this
      is there any way i can type on more than 1 line without having to select option 7 for each line?
      • Neville Bailey
        • 2786
        Yes, after selecting option 7, press the tab key. You will then be presented with a free-form text box in which you can type as much as you like. Once you have finished typing in your remarks, press the tab key again and then press Save.
        • saxophone
          • Sep 2014
          • 10
          Hi Neville
          I have done this and get the free format box
          the problem is I can only type 1 line at a time and the typing does not scroll onto the next line so this is problematic
          I am sure there is a solution - I just cant work it out
          Please help
          thanks
          • Neville Bailey
            • 2786
            Sorry, my steps were not completely correct. Here they are again:
            • Select option 7 (Remarks)
            • Press F5 function key, or click on the Zoom icon
            • Press the Tab key - you should see a large text box appear
            • Type in your remarks
            • Press the tab key again
            • Press the Select button
            • saxophone
              • Sep 2014
              • 10
              Thank you Neville
              You are a genius!
              • saxophone
                • Sep 2014
                • 10
                Hi Neville
                Sorry to bother again
                The free format works perfectly except when it prints on the face of the invcoice the column is quite narrow.
                I have tried to widen this by expanding the blue dots around the data field on the forms designer but this has not helped
                Is there a way to widen the Description column on the face of the invoice
                Thank you
                • Neville Bailey
                  • 2786
                  Be careful when you adjust the width of the description column on Forms Designer, as you can mess up the entire layout of the printed invoice if you inadvertently overlap the description column with either of the columns on the left and right.
                  Where did you save the edited form file and what is the name of the form file that you edited? If you are printing on plain A4 single-sheet paper, then you need to edit the file named csdocsp.enz and save it into your company folder.
                  In any case, adjusting the column width in Forms Designer will only adjust the width of the printed invoice, not the width of the processing window.
                  • saxophone
                    • Sep 2014
                    • 10
                    Thanks Neville
                    i have separately emailed you a copy of the relevant documents also related to my previous query about inserting logos
                    So you will have the document and see what i have done
                    Your feedback is appreciated
                    • Bandles
                      • Oct 2014
                      Hi Neville,
                      I edited csdocsp.enz for my quotation file. However, I have challenges with the size of the detail section which only takes up 16 lines. I need to increase the number of lines to about 22. Please advise on how to do this.
                      Best Regards
