Pastel: Description field on Invoice.....how do I increase size? - The Forum SA
  • TravisZA
    • Sep 2014
    • 108
    Hi,
    I find that the space I have available in the description field on a Pastel invoice is often not enough to complete all the information I want to put onto the invoice.
    Is there any way to increase the size?
  • Neville Bailey
    • 2786
    • Select option 7 (Remarks)
    • Press F5 function key, or click on the Zoom icon
    • Press the Tab key - you should see a large text box appear
    • Type in your remarks
    • Press the tab key again
    • Press the Select button
    • TravisZA
      • Sep 2014
      • 108
      Thanks Neville. So simple once someone shows you how.
      • TravisZA
        • Sep 2014
        • 108
        Neville, since you are the Pastel guru I have another question on invoices - is there any way to make the "Quantity" and "Unit price" fields editable if I'm not processing from Inventory?
        I.e. I want to enter in the GL code and then manually put in the quantity and unit price
        • Neville Bailey
          • 2786
          Unfortunately it is not possible to use the quantity and unit price fields if you using a GL code.
          What you can do is create one or more inventory codes, as service items (not physical items), and then, under Setup...Inventory, create an Inventory Group for each of those inventory items, and then map them to the relevant GL account.
          • Colette810
            • May 2019
            Hi which is option 7
            • Kevin Smith
              • Aug 2018
              • 262
              In the type column (the first one on your invoice) - where it normally shown 4 - inventory item - change that to 7 to be able to input a remark.
              Kevin Smith
              KS Consulting
              www.ksconsulting.co.za
              • Colette810
                • May 2019
                Thank you
                • Ansiep1
                  • Jul 2020
                  Terms Message size.
                  Hi Neville. Is it possible to change the size of the terms message at the bottom of a statement? I need to add notes and do not know how to do that.
                  • Neville Bailey
                    • 2786
                    You can a text box using Forms Designer.
                    Send me an email if you want to arrange a remote TeamViewer session.
                    • Ansiep1
                      • Jul 2020
                      Hi Neville. Thank you so much for your assistance via Teamviewer. It is really appreciated.
