Status 3112 error - The Forum SA
Status 3112 error
  • antcor
    • May 2016
    Status 3112 error
    Pastel Partner keeps on giving me the following message: "Status 3112 (Corruption in open item file)", and I have to close pastel. 2 Days ago I installed windows 10, and there were guys that worked on our electrical cables. This does not happen to the server pc.
    Any suggestions please.
  • Neville Bailey
    • 2786
    I suggest that you open Pastel's Rebuild utility and then rebuild the file named accoi.dat, which resides in your company folder.
    Before doing so, make a backup of your company.
    • Azhar
      • May 2015
      • 6
      Try repairing the install file:
      Click on Start
      Search: ''Programs and Features''
      Look for Pastel and select it
      Select repair
      • antcor
        • May 2016
        Must this be done on the server laptop, as the error occurs on the other 3 machines, just not the server one.
        • Neville Bailey
          • 2786
          You can do it from any of the machines, as the company folder (which is located on the server) can be accessed from any of the machines.
          • kevvie
            • May 2014
            • 32
            Error 3112
            This is a ongoing problem for 99% of people I know who uses Pastel. Its really frustrating. Rebuilding does not work, reinstalling and repairing doesn't work. It's really frustrating.
            • Adepsa
              • May 2017
              • 16
              Hie Guys I have a stand alone machine running on windows 8. I have pastel Partner version 12 running on the machine. I am having a problem when I want to log into pastel I get and error written as status 81(Lock Error) File 7(User File - accuser.dat) Opcode 27(Unlock) and the only option I have is to close pastel. How do i get rid of this error. Please anyone to assist
              • kevvie
                • May 2014
                • 32
                Hi Adepsa, what I would try is to make sure Pastel is closed, go to your Pastel directory and make sure folder permission is set to Everyone. open pastel and see if that helped, otherwise, you will have to rebuild the accuser.dat file via the rebuild utility. make sure you have a valid working backup before you do this.
                • kevvie
                  • May 2014
                  • 32
                  I have found the main problem for me, regarding the 3112 error that keeps coming up, it's because of the network switch we had in, or the switch was faulty or not set up correctly. I replaced that with a normal hub and all is well, only receive status 7 errors now in the accprd file, that's Pastel's main problem that they can't figure out since they started their software. all they say is rebuild a bunch of files, that doesn't work though. I don't think these kind of errors comes up in their high end package like Evolution as it uses SQL instead of pervasive.
                  • Adepsa
                    • May 2017
                    • 16
                    I have rebuilt the accuser.dat and shared the pastel folder but the error is still coming up. but if i log on via point of sale i do not get the error.
                    • Adepsa
                      • May 2017
                      • 16
                      I have even taken the folder to another machine where I installed pastel but still i get that error coming up. What could be the problem?
