where to capture VAT refund? - The Forum SA
  • SilverNodashi
    • May 2007
    • 1197
    [Question] where to capture VAT refund?
    Hi,
    Quick question, in which "chart of accounts" / "set of books" does one normally capture a SARS VAT refund? And what would it be classified as? Would it be seen as revenue, or "what"?
    P.S. I did try and search, but the forums can't find "VAT"
  • SilverNodashi
    • May 2007
    • 1197
    I use XERO accounting, due to it's integration with our Woocommerce website. It works very similar to Quickbooks, if that helps at all?
    • EAB
      • Jun 2016
      • 88
      You need to allocate the refund to the VAT control account, the same as with VAT payments.
      Wisdom is to do now what you will be satisfied with later
      https://erasmusw.wixsite.com/e-ab
      • SilverNodashi
        • May 2007
        • 1197
        Hi Werner_E,
        Thank you. So, would it be considered a "credit note", or how else (apart from using journal accounts), would I enter it, since I didn't issue an invoice either.
        • Mike C
          • 2893
          Not sure about your accounting program, but on mine I enter it via the cash book when it reflects as paid in or out on my bank statement.
          • EAB
            • Jun 2016
            • 88
            As Mike C said, you enter it directly via the cash book.
            When you receive the refund form SARS, and you update your bankstatements in the cashbook you allocate it to the control account
            • SilverNodashi
              • May 2007
              • 1197
              Thanx that was a good tip so I ended up capturing it when doing recon.
