Barcoding - The Forum SA
Barcoding
  • HCSmit
    • Mar 2017
    Barcoding
    Good Morning to all readers
    I had the misfortune to print a few thousand labels vertical, meaning that you have to tilt your head 90 degrees to read. Apparently Pastel Evolution requires that the text input must be horizontal. This will mean that the labels are double the width and had to go on a more bigger and expensive machine before it go to the Bar code label printer. Anyone know of a way to tilt the text in Evolution
    Regards
    HCSmit
    I don't have any labeling advice I'm afraid but welcome to the forum.
    • HCSmit
      • Mar 2017
      I placed the post in March 2017. Nobody could help me then, maybe things have changed sins then so here it is again.I had the misfortune to print a few thousand labels vertical, meaning that you have to tilt your head 90 degrees to read. Apparently Pastel Evolution requires that the text input must be horizontal. This will mean that the labels are double the width and had to go on a more bigger and expensive machine before it go to the Bar code label printer. Anyone know of a way to tilt the text in Evolution
      Regards
      HCSmit
