Run Time Error 35602 - The Forum SA
  • Benny
    • Oct 2017
    [Question] Run Time Error 35602
    Hi All
    i have changed the name of my computer and now i get a run time error 35602 and 440 in pastel express 12, i am running windows 10.
    i have seen posts about changing regedit,because of duplicate companies, but softline does not appear in the H_KEY local as explained.
    thanks
  • UniquelyJanine
    • Mar 2017
    • 40
    You will have to get a new reg code from pastel. The reg code is based partially on your computer name.
    I`m assuming you can open pastel at all? If you rename your pastel12\registration folder to registration old and then run a repair from the cd it should reset and clear your registration files. This will allow you to open pastel but you wont be registered anymore.
