QB Pro 2015 Script Error
  • Questor
    • Nov 2017
    • 56
    [Question] QB Pro 2015 Script Error
    Hello
    When I select any client, the Help window for logging in to UK Support pops up, followed by this script error.
    Script Error
    Line: 53
    Char: 5
    Error: Unable to get property '0' of undefined or null reference
    Code: 0
    URL: file:///C:Program%20Files%20(x86)/Intuit/Quiclbooks%202015/HelpResources/rtl.html
    I have uninstalled and reinstalled the program to no effect.
    Anyone had the problem?
    • 22821
    Originally posted by Questor
    When I select any client, the Help window for logging in to UK Support pops up, ...
    I haven't had the script error, but I had that UK Support pop-up start uninvited a few weeks ago. I managed to kill it eventually...
    Did it start popping up uninvited for you too?
    • Andromeda
      • Feb 2016
      • 735
      Try this solution:
      Launch Quickbooks and open a company file
      Select Help and Live Community
      Exit live Community
      At that point you should be presented with a Open Live Community When Starting Quickbooks message
      Make sure that the radio button is not ticked. See the image
Name:	Live Community.png
      • Questor
        • Nov 2017
        • 56
        It did, just as you experienced it. Andromeda offered a solution but no luck there. So I'll try QB UK.
        • Questor
          • Nov 2017
          • 56
          To avoid the script error popping up, Quickbooks SA suggested I upgrade to QB Pro 2018 as they are aware of a conflict between older versions of Quickbooks and Internet Explorer 11.
          I downgraded to IE10 and the script error no longer appears.
          The QB UK help window still appears, though, so I reported that to QB as a bug.
          Thanks for your help. Most inpressed with The Forum SA!
