Sage evolution POS not working
  • Murray123
    • Apr 2018
    Hello all
    We ran into a problem over the weekend where our POS tills(which run on Sage evolution version 7.20.5.001), were not loading items into the invoice from the barcode search bar and the item search button has been greyed out(we would enter the item description as per usual but the program wouldn't search or load any of the items). While running some tests on backups we found the system worked if we set the date to the 31/03/2018 but as soon as we set the date to 01/04/2018 or any date after the tills would run into the same problem.
    We also found the error message of "Transactions to the selected date have been blocked! you will not be able to process transactions to this date" when we manually tried setting the date as opposed to using the system date. Not sure if this is related
  • Murray123
    • Apr 2018
    Any help or suggestions would be appreciated
