Good Afternoon,
I've been desperately trying to import inventory in Pastel Xpress V17.
Here is what I've done so far, so not to mess anyone around.
1. I.m now suck with an error code: Line 1: Group code does not exist? This is the only error as I have worked through all the others.
2. I did export from Pastel as my example sheet
3. It was exported in .csv format
4. I'v also removed all blank spaces, so that has corrected that error
5. Took out all " and any funny little characters that may cause problems
6.Pastel V17 does not like the standard .xls layout that pastel has provided, it tells me that the layout is incorrect.
Other than this, the only error i'm getting is with line 1: Group code does not exist.
So I'm at my wits end as I've checked everything
Just to also say thank you to Neville for providing a CB layout.csv this works perfectly. So i know a .csv layout does work, maybe I have done something wrong, on my spreadsheet?
If anyone has a little advice thank you in advance
Kind Regards
Kind Regards
