Pastel express start up
  • Kikker
    • Feb 2019
    • 4
    [Question] Pastel express start up
    Good day
    I bought a new laptop and re-registered my Pastel Express Start-up account successfully.
    Now I want to load my excisting company on my new laptop via a backup from my old laptop. I did that, but realised I used the backup that was on my external harddrive. So if I remove my harddrive all the info was gone. So I removed that company from my pastel. But when I tried to create the company again using a backup saved on my new laptop it says the following: Your registration allows you to create 2 companies, you have exceeded this number. Does it mean I did not remove that company successfully? There is no company when I open Pastel.
    What can I do to load the my excisting company from my old laptop to my new laptop.
  • Mike C
    • 2894
    Hi Kikker. Have you gone into your hardrive and looked inside the pastel folder? Even though you may have removed it via the Pastel menu you might still have a folder there with the name of the company your are trying to install.
    • Kikker
      • Feb 2019
      • 4
      Yes but my external harddrive is disconnected.
      • Mike C
        • 2894
        And if you reconnect your external hard drive does that change anything?
        Have a look at this solution and see if might help?
        Hi everyone I just installed Pastel 18 but i opened the wrong company folder and the license is for one company. is there a way to disable it and activate another company?
        • Kikker
          • Feb 2019
          • 4
          I did got the company now from my harddrive and it is installed om Pastel, thank you for that. But now my problem is, its on my external hard drive. How can I get it on my laptop?
          • Kikker
            • Feb 2019
            • 4
            Thank you thank you another thank you. You solved my problem. I opened the link and did accordingly. Reset and installed the back up from the C drive. You saved me a lot of frustration to get hold of Pastel. Thank yoh
            • Mike C
              • 2894
              My pleasure.
