Status 30
Tags: None
Open the company you are trying to copy. Run the data integrity check to confirm that the file is valid in the original database. Close Pastel. Make sure there are no other users logged into the company. Browse to the folder (local or server) in windows explorer. Copy the folder and paste it in the same directory. Rename the folder to the new DB name you want. Open Pastel. File - Open - Add Company - Browse for folder and double click it. Select ok. It will now appear in your company list. You can then edit the setting you want changed under Setup - Company Parameters.
