Easyfile Error 3213 - The Forum SA
Easyfile Error 3213
  • Mel123
    • Aug 2013
    • 22
    [Question] Easyfile Error 3213
    Good morning to all,
    Can anybody please assist with an Easyfile error. I am trying to restore DB on Easyfile but keep getting error 3213.
    Your help will be much appreciated.
  • Kevin Smith
    • Aug 2018
    • 262
    Please give more info. Is this during the restore process. Are you trying to restore a zip file or a .dbz file?
    Make a backup of your existing data in case, then if you close easyfile, you can copy the .dbz for your specific company from your backup into c:\username \ appdata\roaming\easyfileemployer. whole bunch of numbers\local store
    You can get the by holding the windows and R keys down, and typing %appdata% in the run block. Then select roaming, easyfileemployer.67547675 then local store.
    Each company database is a series of numbers.dbz and the numbers are your companies PAYE number, if you have multiple companies.
    Kevin Smith
    KS Consulting
    www.ksconsulting.co.za
