Lost my EasyFile with no Backup :( Help
  • Zany10000
    • Aug 2020
    hi All
    I need some help.
    I lost my EasyFile DB, without a backup. My harddrive crashed on that pc.
    Now i need to get an irp5 for an employee but i cant find it as my easy file is out of date.
    Any ideas what i can do
    Kind Regards Thanks in advance
  • Andromeda
    • Feb 2016
    • 735
    Hi Zany1000
    The person's IRP5 data will be populated on his tax return. If you use a payroll program there ought to be an IRP5 from that system too.
    • Zany10000
      • Aug 2020
      Thanks for help. My employee says when they refresh the data the irp5 doesn't populate.however when I check my paye dashboard it shows I submitted 2 certificates. Not sure why it didn't pull on her side. Can I resubmit my irp5s for that period?
      • Andromeda
        • Feb 2016
        • 735
        You could I guess. I have a scenario now where SARS have duplicated the submission..... in other words they did not cancel the first one, so they are demanding a considerable sum from the client, whereas they have erred. That also means they are non-compliant which effects their ETI as well as their TERS relief. I mention this only so that you know there are risks.
        If your employee's data is correct, ie the tax nmber and ID number, then I find it strange that it does not appear on the tax return.
