Pastel Accounting Xpress Srart Up
  • Tendai Hanyani
    • Aug 2021
    I would like to reinstall pastel accounting Xpress on a new laptop but the laptop does not have an optical drive for the CD. Anyone who can assist.
  • Mike C
    • 2895
    Hi Tendai. Neville Bailey should be able to help you with a link where you can download Pastel. You will probably need to specify which version and build you have on your disc.
    If he does not answer this post, then send him a private message in case he missed it.
    The other option is to buy an optical drive which plugs into your usb port which you can keep in the cupboard and use when needed.
    • Neville Bailey
      • 2786
      Hi Tendai,
      As Mike mentioned, please let me know which version of Pastel Xpress you need to install, and I will send you a link to download the installation file. You will also need to install Pervasive SQL, so please also let me know which version of Pervasive you require.
