easyfile -forms viewer 1.3.1 -just hangs doesn"t open
  • Fareed
    • Oct 2017
    • 17
    [Question] easyfile -forms viewer 1.3.1 -just hangs doesn"t open
    Please assist ,someone -easyfile -the forms viewer-1.3.1 just hangs when you go to declarations..it does not open..?what to do..?
  • Mike C
    • 2895
    Hi Fareed. See the following suggestion from Dave A
    The EMP501 August Reconciliation season has opened once again with updates to e@syfile to be done first. Mine normally suggests an automatic update which "usually" works. This time I got as far as getting the figures from SARS and I was told that the e@syfile viewer was not installed. So off to a full download
    • Fareed
      • Oct 2017
      • 17
      Hi Mike
      Thank i'll try it.
      • Fareed
        • Oct 2017
        • 17
        Hi mike ,i tried it, it did not work. im using 1.3.1 ,what to do.?please help
        • Mike C
          • 2895
          Hi Fareed - I eventually chose the option to put figures in myself rather than import them from SARS and that worked for me.
            • 22821
            I was going to say "try after normal working hours", but judging by the date and time of the post Fareed was trying on a Sunday
            Are you sure the viewer has upgraded?
            (I suspect that was the actual source of my problem - it looked like the upgrade had completed, but in reality it hadn't).
            • Fareed
              • Oct 2017
              • 17
              Hi Mike,
              thank you for that help.
              then does it allow you to edit the emp501 and then file..?then must i go to submissions as normal..? (emp is saved ,but i cannot file..?)
              • Fareed
                • Oct 2017
                • 17
                hi dave ,
                thanks
                if it didn't how do i fix..? the viewer ...but is says ..1.3.1
                  • 22821
                  Hi Fareed,
                  I suspect you are stuck doing it Mike's way if the upgrade of the viewer definitely worked.
                  The real bottom line is SARS needs to get its programming act together to stop these weird errors...
                  • Christel
                    • Feb 2012
                    • 362
                    The correct version of Easyfile is currently 7.1.9 and the Forms viewer is still on 1.3.1. You have to make sure the forms viewer did update - by going to Utilities / System Config / and click on the "forms viewer" install. Make sure the path shows correctly after the installation.
                    • Mike C
                      • 2895
                      Hi Christel. What is the correct path supposed to be?
                      • Fareed
                        • Oct 2017
                        • 17
                        hi all.
                        if i move the location of the file(file viewer) to downloads,do i have to change the paths as well..?-at system utilities.
                        • Fareed
                          • Oct 2017
                          • 17
                          hi
                          still nothing working, viewer doesn't open ..only blue dots.hanging what to do..?
                          • Mike C
                            • 2895
                            Hi Fareed - Perhaps you could try loading Easyfile on another computer (if available) and copy your backup to that computer to see if that makes a difference?
                            Here is also a link with info on EasyFile that you might find helpful.
                            Are you having problems with SARS Easyfile Employer and getting no help from SARS. These hints and tips from users may help. Backup your data before any troubleshooting.
                            • Fareed
                              • Oct 2017
                              • 17
                              Hi Mike
                              i tried installing on another computer..still the same result..the viewer1.3.1 still just doesnt open.it didnt work.
