Pastel Xpress + Thunderbird + Win 10
  • BikerBob
    • Apr 2021
    • 22
    Hi.
    Trying to send email through pastel in Windows 10. Says there is no email associated. Thunderbird is set as default. I even set outlook as default and no luck. Any suggestions?
    Thanks in advance.
  • Neville Bailey
    • 2786
    I can't comment on Thunderbird, but with regards to Outlook, make sure you have installed the 32-bit version, not the 64-bit version.
    • BikerBob
      • Apr 2021
      • 22
      Thanks. I did check that and reinstalled the 32 bit version, but still same issue. I am going to try an set Outlook to the default and see if I can just get that to work.
      • Mike C
        • 2895
        Hi BikerBob, we are using Thunderbird ver 128.11.Oesr (32-bit) with Pastel version 18 and it is working without a problem.
        • BikerBob
          • Apr 2021
          • 22
          Hi. Thanks. It was working perfectly before I upgraded to Windows 10 from 7
          • Mike C
            • 2895
            I am using windows 10 as well. But then I installed Pastel on this platform. It definitely has something to do with the 32 bit vs 64 bit versions of the email programs. I had the issue when I upgraded my Thunderbird to a 64bit version, but after I uninstalled Thunderbird and downloaded the 32 bit version had no problem anymore. From what I understand you have done this already, which leave me a bit perplexed. You have no doubt also set your default email program to thunderbird?
            • BikerBob
              • Apr 2021
              • 22
              Thanks. I finally managed to get it to work. All I had to do was in Thunderbird was to set it as the default mail. I was doing it in windows 10's default app settings
              • Mike C
                • 2895
                Well done. Glad you could get it sorted!
