Sage Pastel Deposit Posting Error
  • Tat
    • Jan 2014
    • 33
    Hello,
    Kindly assist. I posted to the wrong cashbook when I was depositing funds using the deposit assistant under the receipt module. How do I reverse this deposit and post to the correct cashbook.
    Kind regards,
  • Mike C
    • 2895
    Hi Tat. I assume that you have updated the cashbook already.
    Whenever making corrections I find it important to first make a backup, so that once the correction is made you can check that it has worked as you planned it to work. If not, you restore your backup and try again.
    The best way is to enter the details in exactly the same way as it was entered previously in the incorrect cash book. If you posted under Income, enter it under income again - if it was posted under payments, enter it under payments again - same date, same reference everything EXCEPT that this time you make the amount a minus figure. That will reverse the incorrect entry.
    Then enter the details again in the correct cash book as you intended it to be.
    Remember that it will not reflect in your reports until you update your cashbook with the correction.
    Hope this helps.
    • KBMoyo
      • Aug 2019
      • 17
      Originally posted by Tat
      Hello,
      Kind regards,
      How about making a transfer from one cashbook(the one you erroneously deposited) to the correct one
      • Tat
        • Jan 2014
        • 33
        Good day,
        Thank you Mike C and KB Moyo, issue resolved.
        • sassasc
          • Nov 2025
          Glad to hear the issue is resolved. For future reference, the method Mike shared is the safest — reversing the entry using the exact same details with a negative amount, then reposting correctly. Doing a cashbook-to-cashbook transfer can also work if the situation allows it, but the full reversal method keeps your audit trail cleaner.
