Pastel Forms Design help, please
  • DaisyGirl
    • Sep 2010
    • 18
    Hello - Can anybody help with Word Wrap in Pastel Partner Forms Design, please?
    My Company name is fairly long and right justified. At the text box border the name stops and I cannot get it to continue onto the next line.
    Grateful for your help.
    Kerry
    • 22821
    Just how many characters long is the company name?
    I'm not familiar with the Pastel Forms Designer (I'm a Quickbooks user myself), but perhaps this might help anyway. They're the sort of thing you'd try with Quickbooks (which can also pose a similar challenge in terms of displaying long company names).
    • Change the font size to something a bit smaller. (You can also try changing the font type - some take up more space than others).
    • Resize the text box the company name is displayed in.
    • Add a custom field and use that for part of the company name.
    Hopefully something out of that helps, at least until a Pastel user comes along with some suggestions.
    • DaisyGirl
      • Sep 2010
      • 18
      Thanks Dave but I specifically need the company name to be the size it is and to be wrapped onto a second line. In Excel, for eg, you select the cell and Alignment - wrap text. Surely Pastel has something like that? It's well hidden if there is!
      • greghsa
        • Aug 2010
        • 57
        Firstly which version of formdesign are you using Formsdesigner.exe or FormsDesignerV11.exe. I would definately recommend you use Formsdesigner.exe (find it windows explorer under Pastel directory). Open the form eg. csdocsp.eng . You can then go to insert..text. You will have to split your company name into two different text messages (as Pastel formdesign does not wrap text). Once this is done drag text to the desired location.Once this is done, right click on text and select individual font and choose the font you want. Do this for both text messages. Save form. Minimise formdesign .Test print if it is not alligned maximise formdesign move and save etc. It might take a little time but I you will definately get it right!
        • DaisyGirl
          • Sep 2010
          • 18
          Hi Greg, thanks for your reply. I don't use the .exe, I open the form through Utilities - Forms Designer. The fonts and designing is fine, it's just that word wrap which I have been hunting for! As the Blue writing is Database text, it sucks the text in from the Database as a complete name. Splitting it is not possible. You can't only grab half of the company name. I need my company name to wrap onto 2 lines and can't figure out how to do this!
          • greghsa
            • Aug 2010
            • 57
            Sorry there is definately no word wrap in Pastel Formdesign, but there are definately ways around it.
            • DaisyGirl
              • Sep 2010
              • 18
              Cool! Thanks Greg. I'll stop looking now and start working on the ways around it!
              Thanks everybody!
              • Martinco
                • Oct 2008
                • 927
                I would suggest you do a complete setup in Word and import this as a "picture" into the name and address field after you have deleted the existing data fields in the top left hand rectangle .
                You might have to fiddle around a bit with the size of the field/word document but this is what I did and it works well. Just make sure the file that you import remains in the folder from where you imported same because Pastel will always look for this file in that specific folder. ( Maybe best before you import to write this " picture" file to your Pastel folder.) I always keep this file in my c:\Pastelxx\Companyname
                Also your csdocsp.eng will now change to a csdocsp.enz file and should you have to change anything again you have to open the .enz file. Also best to keep this .enz file in the company folder.
                Hope this helps.
                Martin Coetzee
                www.straptite.com
                • DaisyGirl
                  • Sep 2010
                  • 18
                  Ahhh a way around! Sounds like the sizing may be bit of a fiddle. Thank you. I will definitely give that a try.
                  • The Evil Skeletor
                    • Sep 2010
                    Hi DaisyGirl
                    One thing that has worked for me was to add text fields to my form. And remove the company name field from the form.
                    • Martinco
                      • Oct 2008
                      • 927
                      Originally posted by The Evil Skeletor
                      Hi DaisyGirl
                      What I find frustrating about this is that you have to really fiddle around with the sizes of the fields and make sure they do not overlap and to make sure your text and font size fit into the field/s. Also to align the fields takes some getting used to especially if you have a lot of info to fit into the box.
                      I think Daisy Girls real problem is the font size and the fact that the text is right aligned. But yes.....can be done.
                      The other problem that arises from time to time is that if you use more than one printer to print invoices etc. you might find it prints fine on one printer but not on the other one. So...it is trial and error.
                      Martin Coetzee
                      www.straptite.com
                      • DaisyGirl
                        • Sep 2010
                        • 18
                        Thanks Evil... I have changed my form so as not to pull the company name from the data base. I have made text fields instead, splitting the company name 'manually'. Is that what you mean?
                        Pastel has some awesome features, then they omit the basic ones! Like, for eg, discounts receivable from suppliers. There should be some wee button (like the cool one to process overdue customer interest) to calculate what is due to suppliers with an option to apply or change.
                        DaisyGirl
                        • Gerrie
                          • Mar 2017
                          I use both QuickBooks and Pastel. (Still learning Pastel)
                          In Pastel 17 on the forms designer you just drag the size of the field where the name must display the correct length and then down to compensate for two lines of text (or more for three lines). You will have to play around and print to see the outcome. The text will wrap automatically.
                          • UniquelyJanine
                            • Mar 2017
                            • 40
                            Just adjust the field size horizontally and it will wrap automatically. Let me know if you need help with this.
