Error code 20
  • KimH
    • Jul 2010
    • 362
    Error code 20
    I use Pastel Xpress V11 - earlier when attempting to open the programme, I received an error code 20.
    For the life of me I cannot find where to restart the Pervasive engine (assuming that's the problem).
    Any advice? My pastel reseller is not available today to assist, and I didn't want to re-install pervasive unnecessarily.
    Thanks in advance.
  • Martinco
    • Oct 2008
    • 927
    Find Pervasive in your 'Programs" and "Start Engine"
    But Pervasive should start automatically upon PC startup.
    Is there no pervasive icon in your task bar ? If so just right click on this and you should be able to start and stop the engine.
    Martin Coetzee
    www.straptite.com
    • KimH
      • Jul 2010
      • 362
      That option was not available. I have however re-installed Pervasive, everything is working the way it should now.
      • Martinco
        • Oct 2008
        • 927
        Well done !
        Just a tip...................Do not simply uninstall Pervasive. Use "Pervasive System Analyzer" to do the uninstall as normal uninstall does not remove all the elements and can be a problem afterwards .
        Martin Coetzee
        www.straptite.com
        • Neville Bailey
          • 2786
          Glad you sorted the problem out Kim!
          In future, if you need help, and you can't get hold of your reseller, drop me a line and I can assist you remotely.
          • KimH
            • Jul 2010
            • 362
            Thanks for the tip Martinco
            Neville, thanks I will certainly do that - it was frustrating as heck as I was going to receipt my first payment from a client - a historical moment in any business
              • 22820
              • Jon Lown
                • Feb 2019
                • 7
                I need assistance with this error ie pervasive error 20
                I have just upgraded my server machine from windows 7 to 10, and needed to reinstall programs including pastel partner version 14
                I normally install this then pervasive - I am familiar with this process and know to set the parameters for pastel installation
                After installation, I try to run/open pastel -it starts to open then give me pervasive error code 20
                "Your pervasive engine is not running or licenced "
                It know it is running (I know how to check this)
                WHen I check the licence admin it says there is a permanent licence and temp licence
                I have a 10 user licence and the licence admin does not show this - shows a 5 user - but normally when I launch pastel I register it and this corrects the licensing too
                But I cannot do this without opening the pastel program
                Somewhere deep in my memory I remember that when reinstalling on the same machine (even if changed OS) one needs to unlicensed or remove the license and re-license
                Have no idea how to do this - can anyone assist?
                I have un-installed and re-installed, cleaned the registry but no luck
                What am I missing ....
                • Neville Bailey
                  • 2786
                  Hi Jon,
                  Which version of Pervasive have you installed (V9 or V10), and is it the Workgroup edition or the Client-Server edition?
                  Assuming it is the Workgroup edition of V10, did you install it as an application or as a service? Try uninstalling Pervasive and reinstall the other option from what you originally installed.
                  • Jon Lown
                    • Feb 2019
                    • 7
                    Hi Neville
                    Pervasive 10.3 workgroup edition
                    I have got pastel to work on my server but when workstations log in they get error code 20
                    If I go to licence administrator it says
                    temporary 5 user expiring 25/05/20
                    permanent 1 with no expiry
                    BUT I have a 10 user licence so this is not correct and I dont know how to change or correct this
                    Jon
                    • Neville Bailey
                      • 2786
                      Have you tried reinstalling Pervasive, this time using the other option (service vs application or vice versa)?
                      • Jon Lown
                        • Feb 2019
                        • 7
                        I uninstalled pervasive and re-installed it as a workgroup
                        I then re-registered pastel
                        This corrected the issue with the user license ie it reflected 1 + 9 which is correct
                        It did not change the error 20 staff were getting when logging in through terminal server - so I contacted sage help, paid the R950 hourly rate and they tweaked windows 10 settings and other "hidden" pastel settings and presto it worked
                        Thanks for responding and had I not been impatient with staff breathing down my neck I would have taken a slower route
                        Jon Lown
