Thanks again Neville!  The correction hit the mark!
I have run tests against what Pastel reports is the Stock on Hand and it all matches except for unposted orders.
The formula below calculates Stock on Hand which does not cater for unposted orders. This means that if the order filling part of your operation does not run frequent updates, then the online stock may become incorrect and possibly cause frustration and anger with Internet customers (as well as with those having to deal with the customers).
One of the accounting ladies mentioned that Stock Available (instead of Stock on Hand) may take unposted orders into consideration and provide a more accurate stock count although (a) I'm not sure about this and (b) I don't know how to calculate Stock Available. Any best practice insight / advice / info on this?
For those interested, here's the working formula for Stock on Hand as implemented in PHP:
PHP Code:
$qO = (int)odbc_result($rs, "OpeningQty");
$qB01 = (int)odbc_result($rs, "QtyBuyThis01");
$qB02 = (int)odbc_result($rs, "QtyBuyThis02");
$qB03 = (int)odbc_result($rs, "QtyBuyThis03");
$qB04 = (int)odbc_result($rs, "QtyBuyThis04");
$qB05 = (int)odbc_result($rs, "QtyBuyThis05");
$qB06 = (int)odbc_result($rs, "QtyBuyThis06");
$qB07 = (int)odbc_result($rs, "QtyBuyThis07");
$qB08 = (int)odbc_result($rs, "QtyBuyThis08");
$qB09 = (int)odbc_result($rs, "QtyBuyThis09");
$qB10 = (int)odbc_result($rs, "QtyBuyThis10");
$qB11 = (int)odbc_result($rs, "QtyBuyThis11");
$qB12 = (int)odbc_result($rs, "QtyBuyThis12");
$qBL = (int)odbc_result($rs, "QtyBuyLast");
$qA01 = (int)odbc_result($rs, "QtyAdjustThis01");
$qA02 = (int)odbc_result($rs, "QtyAdjustThis02");
$qA03 = (int)odbc_result($rs, "QtyAdjustThis03");
$qA04 = (int)odbc_result($rs, "QtyAdjustThis04");
$qA05 = (int)odbc_result($rs, "QtyAdjustThis05");
$qA06 = (int)odbc_result($rs, "QtyAdjustThis06");
$qA07 = (int)odbc_result($rs, "QtyAdjustThis07");
$qA08 = (int)odbc_result($rs, "QtyAdjustThis08");
$qA09 = (int)odbc_result($rs, "QtyAdjustThis09");
$qA10 = (int)odbc_result($rs, "QtyAdjustThis10");
$qA11 = (int)odbc_result($rs, "QtyAdjustThis11");
$qA12 = (int)odbc_result($rs, "QtyAdjustThis12");
$qAL = (int)odbc_result($rs, "QtyAdjustLast");
$qS01 = (int)odbc_result($rs, "QtySellThis01");
$qS02 = (int)odbc_result($rs, "QtySellThis02");
$qS03 = (int)odbc_result($rs, "QtySellThis03");
$qS04 = (int)odbc_result($rs, "QtySellThis04");
$qS05 = (int)odbc_result($rs, "QtySellThis05");
$qS06 = (int)odbc_result($rs, "QtySellThis06");
$qS07 = (int)odbc_result($rs, "QtySellThis07");
$qS08 = (int)odbc_result($rs, "QtySellThis08");
$qS09 = (int)odbc_result($rs, "QtySellThis09");
$qS10 = (int)odbc_result($rs, "QtySellThis10");
$qS11 = (int)odbc_result($rs, "QtySellThis11");
$qS12 = (int)odbc_result($rs, "QtySellThis12");
$qSL = (int)odbc_result($rs, "QtySellLast");
$qOH = $qO + $qBL+$qB01+$qB02+$qB03+$qB04+$qB05+$qB06+$qB07+$qB08+$qB09+$qB10+$qB11+$qB12 + $qAL+$qA01+$qA02+$qA03+$qA04+$qA05+$qA06+$qA07+$qA08+$qA09+$qA10+$qA11+$qA12 - $qSL-$qS01-$qS02-$qS03-$qS04-$qS05-$qS06-$qS07-$qS08-$qS09-$qS10-$qS11-$qS12;
 info/advice (0835579832).
