Please help, how do i import new general ledger accounts from an excel spread sheet
Pastel General Ledger importing
You need to save the Excel file in CSV format, in a specific layout.
I have attached the layout requirements.
Once you have created your CSV file, go to Pastel and then select File...Export/Import and then, from the drop-down menu, select "Import General Ledger Accounts" and then browse to your CSV file.
Note that you can only import GL accounts if your Pastel database does not have any existing GL accounts.Neville Bailey - Sage Pastel Accounting Consultant
WALLACE WATTLES (1860-1911) -
I get the following errors when trying to import from Excel to Pastel14.
Hi Neville,
I get the following errors when trying to import from Excel to Pastel14. Line 1 period should be 1-13, I have a 1 in that column?
It also complains about the date
Do you see any obvious mistake in layout?
OttoAttached FilesComment
Hi Otto,
The layout of the file seems fine.
However, you cannot import a regular Excel file with the file extension *.xlsx. Save the file as a CSV file, and then you should be able to import the file successfully.Neville Bailey - Sage Pastel Accounting Consultant
Impoting Credit Card Payments into Pastel
Hi Neville,
I want to import Credit Card payments into Pastel, is the CSV file format the same as for Cashbook Csv File.
I getting all kinds of errors. Please help
OttoComment
