Excluding non-executive directors - The Forum SA
  • Beancounter
    • Oct 2011
    • 140
    The board wants to a declare a dividend and claims that the one non-executive director does not want any part in financial decisions and therefore his signature on the resolution is not necessary.
    Section 46 of the Companies Act however is very clear on the declaration of dividends and that the board (meaning each director) should sign the resolution. Further, the new Act does not distinguish between executive, non-executive or independent directors so they have their fiduciary duty to consider.
    I was told that the following could be a solution:
    1) The board passes a special resolution that the non-executive director will not be required to sign off on resolutions for dividends
    2) The non-executive director still has to be informed of the resolution passed
    3) The non-executive director can voice his disagreement with the resolution for the record and then be absolved from any liability in terms of the Act
    Is that allowed?
    No good deed shall go unpunished - Oscar Wilde
  • CLIVE-TRIANGLE
    • Mar 2012
    • 886
    I don't know about that
    How could you possibly avoid, contravene, or bypass a provision of the Act by simply adopting a special resolution?
    So your paras (1) and (3) simply fall away.
    A decision to pay dividends requires an ordinary resolution (simple majority at a quorate directors meeting).
    The Act does not require that each director sign the resolution. That would only be possible if the decision was unanimous, anyway.
    The Act only requires that the company meet solvency requirements, and that is all. It can even pay the dividend out of capital!
    And you are right, a director is a director is a director.
    • Greig Whitton
      • Mar 2014
      • 338
      Section 46 says nothing of the sort. What it actually says is that the distribution of dividends must be authorised by board resolution (assuming that there is no legal obligation to distribute the dividend, in which case a board resolution isn't needed at all).
      Authorising a resolution is not synonymous with signing it. Per section 73(8) of the Companies Act:
      "Any minutes of a meeting, or a resolution, signed by the chair of the meeting, or by the chair of the next meeting of the board, is evidence of the proceedings of that meeting, or adoption of that resolution, as the case may be."
      So the non-executive director can simply abstain from voting on financial decisions and not worry about having to sign anything.
      If he wants to avoid any possibility of liability, then, per section 46(6), he must not be present at the meeting when the resolution is put to the board (which is fine since, per section 73(5b), only a majority of directors must be present at board meetings before a vote may be called - unanimous attendance is not required).
      To the best of my knowledge, there is no way a director can be present at a meeting when a dividend resolution is put to vote and NOT be liable if they know that the distribution is contrary to the requirements of the Companies Act and fail to vote against it.
      Founder of Growth Surge - Helping entrepreneurs create more wealth and enjoy more freedom.
      • Beancounter
        • Oct 2011
        • 140
        I'll go with your point Greig, thanks!
