Procedure To Report Bank To Bank Ombudsman? - The Forum SA
  • neliusmit
    • May 2014
    • 19
    [Question] Procedure To Report Bank To Bank Ombudsman?
    I would like to know what the procedure is to report a dispute to that one has with the bank to the bank Ombudsman. It is just unbelievable how the bank "plays for time"
    and the matter not resolved
  • Houses4Rent
    • Mar 2014
    • 803
    Have a look at their website.
    I simply emailed them my complaint, but I am sure they will take ample time to eventually respond that I have to follow "procedure"...
    Houses4Rent
    083-3115551
    • neliusmit
      • May 2014
      • 19
      Thanks, will do
      • lewskannen
        • Feb 2011
        • 38
        Before you can lodge a complaint with the banking ombudsman, you need to report your complaint to your bank's dispute resolution center and you should get a reference number for the report. After this, you have to give your bank 20 days to investigate and return to you with their findings. If you then cannot resolve this, then only can you lay an ombudsman complaint, at which time you will need the reference number and also provide things such as the reply of your bank.
        • neliusmit
          • May 2014
          • 19
          Thanks for the advice
