Water leak increases tenants bill
  • Basment Dweller
    • Aug 2014
    • 314
    [Question] Water leak increases tenants bill
    Hi all,
    To all the landlords out there, what do you do if you discover a water leak only when you get the utility bill and the bill is 10x it's normal amount?
    Do you impose that cost on the tenant? I haven't really checked my lease but is there normally a provision for this risk to be carried by the tenant in standard lease agreements?
    BD
    Its not the tenants fault that there is a leak - the cost should be for the owner.
    • sterne.law@gmail.com
      • Oct 2009
      • 1332
      You may be covered through the municipal insurance
      Anthony Sterne
      www.acumenholdings.co.za
      • Basment Dweller
        • Aug 2014
        • 314
        Leak is not the tenants fault but how does the landlord determine how much water was used by the leak and how much used by the tenant during that month?
        The leak could've been going for 5 hours or 5 days, how do we know? See where I'm going with this?
        @ Anthony 'Municipal Insurance?', I wasn't aware something like that existed, what is it, and how do I claim?
        • Houses4Rent
          • Mar 2014
          • 803
          What is municipal insurance? Never heard of it.
          Its not the owners fault either by default.
          The big consumption could be many things.
          reading error
          estimate only
          if leak is before the water meter its not billed and the councils baby (must still be fixed as water is precious water)
          if its after the meter it will be billed for and ultimately owners baby
          could also be a faulty water meter, which is council property
          could be a running cistern
          could be wrong pool operation
          could be an mis-programmed irrigation system which waters overnight undetected (a flat battery could cause this)
          etc.
          look for wet patches.,
          Bottomline:
          establish first what the root cause is and then take the next step.
          It also helps to read yoru lease.
          Houses4Rent
          083-3115551
            • Oct 2009
            • 1332
            Check your electricity rates bill
            It should have a line item, water insurance.
            They have a formula to calculate leak.
            Average consumption etc
            Anthony Sterne
            • Houses4Rent
              • Mar 2014
              • 803
              Take the average tenant's consumption in the past if you want to determine what the tenant used and allow for seaonality
              Houses4Rent
              083-3115551
              • Houses4Rent
                • Mar 2014
                • 803
                Electricity bill? I thought we are talking water.
                I have seen thousands of Cape Town council bills by now and never saw a line item of water insurance. Maybe its a Durban thing?
                Houses4Rent
                083-3115551
                • Basment Dweller
                  • Aug 2014
                  • 314
                  Good input thanks,
                  I think what I'll do is take an average for the last six months and offer to contribute something to offset the overrun. Tenant will have to fit the rest of the bill.
                    I'm assuming the leak was outside or it would have been noticed so is the tenant bound by the lease agreement to maintain services external to the dwelling? This would be very unusual if they are. The external building fabric and services is normally maintained by the landlord or owner. I don't see how the tenant could be responsible for the leak or liable for the costs.
                    I know a couple of people who've had a similar problem in Cape Town and both sucessfully appealed to the municipality and got most of the bill waived, I think they had to produce a plumbers report to confirm it was an underground pipe that had leaked and it couldn't reasonably have been avoided. I know that one of them received a R28K water bill originally so if there isn't the 'municipal insurance' that Anthony mentioned and if the waiving of the bill is at their discretion or dependant on their mood on the day, maybe it's worth looking at getting private insurance to cover against this kind of eventuality.
                    • Basment Dweller
                      • Aug 2014
                      • 314
                      I'm going to check with both the municipality and my insurance for cover, if not I'll have to cough up a couple grand. This is why owning property sucks, something always comes up that chews away your profits, after the bond is paid you make nothing.
                        In your first post you said it was ten time more ...... so you know.
                        • Houses4Rent
                          • Mar 2014
                          • 803
                          Ah, you meant your building insurance might cover sudden accidental loss of water maybe. I am still keen to hear whether there is a specific municipal insurance as it was mentioned here?
                          Property investment is/should never be about short term profits, but long term asset building.
                          A landlord must always have a kitty for unforeseen expenses like vacancies, maintenance etc
                          Houses4Rent
                          083-3115551
                          • Basment Dweller
                            • Aug 2014
                            • 314
                            100% correct, rental businesses need to have some floating cash, at least one months rent per unit because these things come up.
                            My insurance doesn't cover water loss and I've been trying to call the city of JHB for the past three days, they put you on hold for 15min then just cut you off.
                              • 22813
                              Ethekwini has a water loss insurance scheme going (which is probably what Anthony was referring too).
                              It would seem from the conversation that not all municipalities have this.
