3d printing
  • hip2bsq
    • Jun 2018
    • 3
    3d printing
    i am a toal newby when it comes to 3d printing but the possibilities are boundless!!! i need help guiding me to create images and download to print....i have a wanhao duplicator i3 plus....the issue here is what is the easiest design programme to use for beginners? i am currently using mehmixer and maker slicer but the prints do not come out the way they should .....i know i am doing something wrong...HEEELLP!!!
    I would download a ready made file like this puzzle from instructables and then print it as is to make sure it works with your printer. If it works use that as a base to play with so you can get used to how to design and what works and more importantly what doesn't.
    Good luck and post some pics of your work.
    • hip2bsq
      • Jun 2018
      • 3
      Thank you for the prompt reply.....when i print off the sd card that came with the printer the result is very good....but when i try and design and print off meshmixer/mattersclice the results are less than good.....is this the program/printer fault or my fault....?
        I don't have a 3d printer so can't help with that. Sounds like some troubleshooting is required.
        • SilverNodashi
          • May 2007
          • 1197
          Designing for 3D printing can be quite tricky and it helps a bit if you have some technical drawing background. As a start, make sure everything is "watertight" in order to print properly, and design with at least 1mm (2mm is better) walls.
