Pastel Forms Designer - The Forum SA
  • Francesvd
    • Sep 2019
    • 7
    [Question] Pastel Forms Designer
    There seems to be too many line items on my invoice / quote /sales orders. 3 Line items are printing below the block. Can someone please advise how I change it so those 3 line items move over to the next page?
  • Neville Bailey
    • 2786
    The most common cause of this problem is that the Description column is too narrow, which causes some lines to wrap onto another line.
    You can adjust the column width in Forms Designer, but be careful not to overlap with adjoining columns. You might need to make other columns a bit narrower to make space for the widening of the Description column.
    • Francesvd
      • Sep 2019
      • 7
      Thanks Neville, But none of my lines wrap onto another line. It seems almost as if too many line items are printing per page, so 3 lines move outside the block in between the line item block and the footer block
