Capturing rounding on invoices
  • duncan drennan
    • Jun 2006
    • 2642
    What is the "correct" way to capture rounding on invoices received? I currently just capture the item at the invoiced rate and then put the rounding against cost of sales (as a negative value). Is that satisfactory?
    • 22820
    Duncan, is this in relation to VAT or a rounding on 'cost per item x quantity' calculations?
    • Marq
      • 1297
      I would just capture the net figure. It's not worth the effort of chasing cents and the receiver is not going to worry about them, knowing that the net effect is so small.
      • duncan drennan
        • Jun 2006
        • 2642
        The case that I occasionally have is when I buy a tool (or something) from a hardware store and there is rounding on the invoice.
        So for example, tool = R43.00, VAT = R6.02, Total = R49.02, Paid = R49.00 (due to rounding). Is the R0.02 a negative cost of sales?
        Marq is probably right, as long as it does not cause a discrepancy in your bank reconciliation.
          • 22820
          OK. I follow now.
          Amended resolution agreed.
