Is it possible to trace the IP address where an email was generated when it comes from a gmail address?
IP Address trace
Tags: None
Hi there I tried Geobytes with both of my gmail accounts and it points to Mountainview CA. So I suspect getting the location of a mail from a Gmail account is not going to be easy no matter which software you use.Comment
You made me check. Gmail does not incude the IP of the user in the header info. So you're right - you can't trace the location of the sender because their IP address isn't disclosed.
