NETWORK CONNECTION PROBLEMS
  • Coolblue
    • Jan 2013
    • 83
    Has anyone any suggestions on how to fix a network connectivity problem I am having. I have a windows 7 (64bit) bootcamp partition and am connecting it to a network (not a domain). I am able to see all the computers on the network except the Pastel server which is a windows 2003 server and a Belina payroll server which is a standard XP machine. I have flushed the ips I have checked the TCP/IP settings, I have checked the workgroup settings. As I mentioned I can all other computers on the network apart from the two mentioned.
  • monaknight03
    • Feb 2013
    • 12
    When you go to your network folder you will get a yellow strip on the top of the page click on that and click network discovery on select your choice you will see the list of computers connected to your network weather WiFi or LAN.
    • irneb
      • Apr 2007
      • 625
      Are those "servers" set to a different Workgroup (seeing as you're not using a domain)? It's highly recommended to use the same Workgroup name throughout (and turn off W7's Homegroup feature if you've got a mix of older Win machines as in your case). This would make network connections much easier.
      You're still lucky you're not having to connect to a 2000 (or even NT4) machine. That's simply impossible through Vista / W7. Ms decided those are not used any more, even though they are used extensively in old setups. If you've got one of these, then you're relegated back to XP as latest Win desktop.
        • 22810
        When you change network settings, it's worthwhile doing a restart - especially on older XP machines to make sure the new settings are actually being used.
        • Coolblue
          • Jan 2013
          • 83
          Thanks so much for your reply I have done that and I see all the computers except the two I mentioned. If I go to one of the machines on the network and I ping the ip address of the computer I am trying to connect I can do that no problem. If i go on the problematic computer and I ping the ip address of the other computers on the network I have no success but if I ping the computer name it replies. The problem with this is that I am using Pastel and Belina and need the ip addresses in order to connect successfully
          • Coolblue
            • Jan 2013
            • 83
            Hi there, I have checked the workgroup settings and they are definitely all the same "workgroup"
            • Coolblue
              • Jan 2013
              • 83
              I def restart each time I make any changes.... but its win 7 OS however I still do the restart.
                • 22810
                Have you tried disabling IPV6 and only have IPV4 enabled?
