Excel Drop down box
  • sterne.law@gmail.com
    • Oct 2009
    • 1332
    Excel Drop down box
    I want to use the dropdown box in my excel, I cant for the life of me remember how.
    I want the dropdown to show the populated list so that the exact word can be chosen.
    if its a plug in any links to same would be appreciated.
    Anthony Sterne
    www.acumenholdings.co.za
    http://www.techrepublic.com/blog/mic...an-excel-cell/
      • Oct 2009
      • 1332
      Man have I been meaning to incorporate this feature for ages, no idea what took me so long to do it.
      Anthony Sterne
      • irneb
        • Apr 2007
        • 625
        Yep, Excel 2007's work like that. But I prefer 2010+: It allows the drop-down's source list to much more easily be read from a table as well (instead of just a fixed address). Works wonderfully for lookup tables!
          • Oct 2009
          • 1332
          I'm finding pivot tables effective for data integrity management.
          Anthony Sterne
            This is the single most useful bit of code I have ever come across for Excel. The code allows you to write modules that are fired during cell entry. So, you are able to fire off lots of different events due to one selection being made in your dropdown list.
            This is my scenario:
            I do laser cutting and when I do costing I need to be able to select one material from a list of 10. The list of 10 materials may have different thicknesses.
            So
            Plywood
            1mm
            2mm
            3mm
            UHI
            1.2mm
            2.5mm
            3mm
            Now, each material / thickness has a related board size and price which gives me a calculated cost / cm sq.
            When I select a particular material I have to restrict the selection of thickness to only those specified for the material type and once I select the material thickness I have to populate the material length, width, price and calculated price / cm sq fields.
            I couldn't figure out how to do this because Vlookup etc is not clever enough to restrict the secondary selections.
            This code allows you to do anything you like once data has been entered into a cell.
            Run the example and you'll quickly figure out how useful the code could be.
            XL: How to Run a Macro When Certain Cells Change
              • Oct 2009
              • 1332
              Hello Adrian,
              I may have a simplier way to do the same
              D E F
              part type supplier
              plywood 2 45
              WOOD THICK COST
              plywood 1 35
              plywood 2 45
              plywood 3 55
              UHI 1.2 65
              UHI 2.5 75
              UHI 3 85
              The table is set
              Two items in bold are the selection criteria
              Coloured number Is the value returned by the following formulae - =INDEX(D7:F12,MATCH(D4&E4,D7:D12&E7:E12,0),3)
              Anthony Sterne
                • Oct 2009
                • 1332
                The smiley face is actually a colon :
                so it reads d7:d12
                Anthony Sterne
                  • 22810
                  I took the liberty of wrapping the problem section with noparse BB tags for you. The unintended smiley is now history
