What are your thoughts on this
SA to get new electrical sockets, plugs
Disclaimer: everything written by me can be considered as fictional. -
Oh wow! So they're adding an Earth to the useless 2-point we're using in SA? I'd rather they simply get rid of them, they never work properly and tend to make poor connection (especially with a one-unit transformer). The round pins were always an issue, the contact points around them are inefficient (as it usually only touches a small fraction of the surface area) and the 2 pins have smaller radius which makes them even more inefficient. I'd say they actually need to get away from these and opt for the square or flat pin designs used overseas - much better contact, much more secure (no wobbling and disconnecting, and (more importantly) less chance of a child sticking their fingers in there!
Obviously that is not practicable as old appliances would need adaptors to work on the new sockets. But this is rather strange, very seldom do you see sockets with the 2 prong plugs - usually you need an adaptor to fit onto a 3 prong socket anyway. Now you'll need an adaptor in reverse for your 3 prong plugs (if you don't have enough sockets for them). I want to see just how many muisneste people are going to construct in their kitchens to get the micro, the kettle, the fridge, the food processor, etc. plugged into those 2 prongs with added earth!Gold is the money of kings; silver is the money of gentlemen; barter is the money of peasants; but debt is the money of slaves. - Norm Franz
You mean like these used in Australia.
I have to renew quite a few "old" 3 pin 16 A sockets in a retirement cottage I'll be moving to and would like to fund the most reliable brand. I.e. Crabtree, CBI, LeGrand or Veti. I'm gioing to be shelling out for about eight and would appreciate advise so that I get the best bang for my buck.Comment
Personally I've found LeGrand more durable. Not to mention, they have a much wider range of appearance. Though I've tended to use these in hotels instead of residential - usually around 5 star hotels or boutique lodges.
However their cheap default switch is the little round one. Might not be ideal for a retirement village. I've found they're irritating as my finger sometimes has difficulty turning it off before unplugging, I can imagine someone with ailments like Parkinsons (like my grand mother had) finding them impossible to use. In which case the Crabtree default large rectangular switch may be more usable.
Of course if you're going for the more high-end designs then LeGrand is definitely the better brand. But they're going to be more expensive.Gold is the money of kings; silver is the money of gentlemen; barter is the money of peasants; but debt is the money of slaves. - Norm Franz
Thanks irneb. Crabtree Topaz offer 2 sets that I'm interested in. One is old 3 pin + 2 Slimline with 2 switches. Two is a bank 4 Slimline witched in 2's. Is it permissible to put these two side by side in a wall but from the same cable feed OR must they b supplied individually. I'll get an electrician to carry out the work.Comment
What about the Veti Omni Cluster https://www.vetionline.co.za/collect...-fixing-frames. the ability to mix and match sockets would be ideal for my Home Office and my Tv area.Comment
Some of these are largish downloads, please be warned if you're on dial-up or limited bandwidth.
Clipsal S3000 range
Crabtree Diamond range
Gewiss Chorus range
LeGrand Arteor range
Schneider Zencelo range
Gira system55 range_______________________________________________
