For those 2 the choices you've listed are way beyond required (probably even beyond recommended). 3D is probably going to be your highest demand software - there it depends from program to program (e.g. SketchUp is much more "lightweight" than Revit, but isn't doing the things Revit can do). Web? If you're just going to use a web page WISIWYG program like DreamWeaver - then that's even less power/memory hungry than the 2D editors, so I'd not worry too much about it.
Are you going to run a web server on your Laptop? You sure? Perhaps for development purposes. In which case you might want to up the RAM & hard drive and install a VM (i.e. a 2nd operating system running inside a virtual machine) for the server, that way you can pick-n-choose from many server OSs (including even Linux) and they won't interfere with the working of your "workstation". But I'd definitely recommend a true PC instead of a laptop for production servers, much more capability to extend stuff like disc space.
Whenever someone asks: "What PC/Laptop do I need?" The first step is always: "What do you actually want to do?" After which you need to choose the software which allows you to do those things. And then you look across all the software you'd need - listing their recommended minimums. Choose the hardware so it's on par or better than the highest minimum of your chosen software.
Note with 3D many of them require very good graphics cards. Some even require better than a high-end gaming card. Yet some "state" they require something awesome, but then when you test it you find it's not really the case. E.g. most AutoDesk products recommend Quadro instead of GeForce and FirePro instead of Radeon. But from my own experience if you go with an entry-level Quadro (around the same price as a very high-end GeForce ~R3000) the same priced GeForce will give you more performance - it's only once you get to the truly expensive cards (R10,000 + for the card itself) where there's a noticeable difference between a R3000 GeForce and a R12000 Quadro (same applies to AMD's Radeon vs FirePro's).
And that's usually the reason I steer clear of a Laptop as a graphics workstation. For the sort of 3D work I do it becomes exorbitantly expensive to get a decently performing Laptop in comparison to a PC.
As an example, we have one guy needing to travel to various countries across Africa and he needed a very decent Laptop to compare to his workstation in the office. His workstation cost around R30,000 total, but when we speced a laptop with the same capabilities we ended up with this: http://configure.us.dell.com/dellsto...n&s=bsd&cs=04&. And after configuring it to match the PC it was around $4500 ~ R48,000
