Laptop getting hot
  • kavesh
    • Feb 2018
    • 168
    Laptop getting hot
    Hi All
    I have an Asus S 550 CB laptop. It really is a nice laptop for its age.
    I have noticed that it has began to get progressively warmer, not to the point of shutting down...but its hot.
    I have removed the fan housing and cleaned it but I must say there was hardly any dirt that could be blocking the fan. I was not able to strip the fan apart as I did not know how to.
    Anyone have experience in this area and can assist with some advise please.
    Kavesh
  • New Perspective studio
    • 170
    Well some laptops do actuall run hot, im not saying leave it but what you can do is the following.
    You need to find out what the problem is as there are a number of issues that can cause this, my first suggestion :
    First Diagnose with software ":
    Speed fan is another software but is intended for Windows only. Mac (OSX) user smcFancontrol. These are temperature monitoring program for fan speed, voltage and processor temperature. It has access to info which helps to evaluate your hard disk’s temperature.
    Core Temp is a tool for the laptop as well as for all desktops. It shows the temperature of each core in colored numbers in the notification area.
    Real Temp is specially designed to determine the temperature for all Intel Single, dual and quad-core processors. It tracks out all the lowest and highest temperatures since when you opened the program.
    If you find issues its best to take it in.
    Some possible causes
    Insufficient Cooling because of the non-working fan.
    Check Air Flow and Heat Transfer for blockages and dust.
    Hardware failure
    -----Check for Dying Batteries
    See if your processing load is causing the issue
    ---Malware attack
    Ambient temperatures ?!?
    " A plumbers tap always leaks " - Great advice from a forum member
    • kavesh
      • Feb 2018
      • 168
      Thanks for the information. I will try download speed fan and see how that goes.
      With the age of the laptop now about 4 or 5 years old, its really not worth spending money letting an IT guy have a look at it. Its a really nice laptop that has been well taken care of and would love to use it for a bit longer.
      I don't have the luxury of saying my 3 year old laptop is fully depreciated and now I can just replace with a new one.
      I will post any results from the speed fan, hopefully its easy enough to work with.
        • 170
        I see your point, If it is the fan ( which by the sound of it wont be clogged up ) you can always get a cooling pad. I also have a HP which is about 6 years old and I love it more than my brand new asus.
        One thing I noted with my Hp is as operating systems upgrade ( even Win 7 which I think they will stop updating soon ) is that the newer updates are always heaver on the cpu, meant for newer cpu's I suppose.
        I run windows 7 ( on the Hp ) had 10 hated it and the load on the old hp was so heavy with 10 it was unbearable.
        With my asus which is about a year and a bit old now after every few windows 10 updates I can see the difference in performance ( ie dropping ) due to just a more demanding os in the Cpu.
        It sucks but great way to keep you buying a new laptop every few years
        • kavesh
          • Feb 2018
          • 168
          Thanks for that info.
          My Asus came with windows 8.1 and they offered an upgrade to windows 10 a few years later.
          From what I understand and have been told my Asus is a 3rd gen i7. An IT guy told me that the 3rd gen i7's suck compared to a more recent i3.
          I hoped that the SSD would have at least stablised the machine to decent performance but it did little in terms of performance enhancement.
          The IT guy also told me that whenever he does installations he disables the windows updates. I wonder whether that is a good idea?
          I know my fan does work as i can feel the air blow and especially when it warms up.
          It is just so frustrating
            I"m not familiar with the Asus, but if there is a power manager, have you optimised for performance? And downrated temperature issues by any chance?
              • 170
              As for the processor part its somewhat true without knowing the exact i3 gen I cant say but newer generation processors are much more efficient at what they do in most cases even if they have fewer cores. So there is truth to that.
              The ssd do improve performance, there are few cases where it would not such as a more recent CPU and core-logic chipset, Is it configured correctly though ?
              Ensure your SATA controller runs in AHCI mode
              Avoid Disk Defragmentation
              Make sure TRIM is running
              Verify Hibernation is disabled
              Enable Write Caching for SSD
              Make sure the SSD partition is aligned
              SSD is slowing down when getting full? Here are 7 quick tricks to make your SSD drive run faster for your reference.
              All the above is from there its not a uncommon issue but one that people can resolve.
              As for the Windows 10 Updates you are honestly asking the wrong guy, As ive said I have 7 on my older hp which i work with most of the time, on my asus i have ten and i have disabled updates, one day when im forced to work on ten I will have a look to see what are better options. Supposedly from the bit that I have discussed on this topic before i gave up on WIN 10 the updates provide important performance enhancements which is great if you have a newer laptop that can utilize it to its fullest not so good if you have a laptop that is already struggling another important feature of updates is security.
              Windows 8 ( never had it ) i heard was an abomination of a OS and this is agreed upon by all people on the web lol and when tech guys agreee on something you know it must be thruth because they love arguing. If you are still on 8 it may be worthwhile to check out 10 ( Make sure you can rollback in the case it makes things worse ) although for older laptops ten takes a lot of configuration to get running smoothly like everything after windows seven, options almost seem hidden you have to go through a few online tutz to find them i know i did.
              To be dead honest with you, I loved windows all the way to seven, after 8 and 10 my next laptop will be a Mac ( even though i dont like them )
              Lastly airflow is good, so no glogging in that part. When last have blown out the laptop case for dust ? Dust can also wreak havoc as a static component inside the case.
              Ive done a few blow outs before and man it changed my laptop it almost felt it ran faster.
              What temps did you get on your gpu and cpu ?
              • kavesh
                • Feb 2018
                • 168
                Hi Dave, I was not able to find a power manger on my Asus.
                • kavesh
                  • Feb 2018
                  • 168
                  Thanks for this detailed response. I am going to research each of the points mentioned and revert.
                  • vieome
                    • 540
                    Press Ctrl Alt Del and go to task manager and check which processes are running and if the CPU usage high?. Get a blower and blow the laptop to remove any dirt, dust collected on motherboard which can make laptop run hot. Another thing to try would be to download a small linux system like puppy linux burn it to cd and insert cd to laptop, boot from the cd it will do a live install and see if you have the same problem.
                    • kavesh
                      • Feb 2018
                      • 168
                      Hi guys
                      I have resolved my ASUS issue. I will repurpose the ASUS for one of my kids.
                      I purchased a HP Probook i5 from one of my clients, was only 18 months old and in really good condition. Busy transferring all my data to the new laptop and installing all necessary applications. Interesting thing was I did not realise that onedrive was running on the HP laptop and man it make the computer so slow. Task Manager showed that the disk processes was at 100%. Not sure what all that means but if obviously was making the laptop work too hard. After disabling onedrive performance was restored.
                      • 2Conn
                        • Dec 2018
                        • 16
                        It could be hot cause of it's nature, you really need to check other parts not only it fan. When it started ? Check even battery of laptop, it may be dying out and it could be the reason of that. I have seen that in past many times. It all like chain reaction. P.S. Oh I see you already fixed the issue, my bad!
                        • rawoke
                          • Sep 2017
                          • 28
                          Try disabling some of your chrome extensions and cleaning up dirty fans ! Worked wonders for me.
                          FibreTiger - Compare ALL fibre Internet Providers in your Area
                          https://www.fibretiger.co.za
